Most of which are a fixed range of lighting and minimal movement of the camera.
Unusual conditions probably refers to camera shake or lighting below the camera's range. Try using a tripod and use sufficient light - does it do this when you use the camcorder outdoors in daylight, or only indoors? If you are shooting hand held try to brace against your body or an object that will not move. These warning beeps are supposed to occur for image quality purposes, and most digital cameras warn you if you are trying to video and the operation is outside the range of conditions that the device "likes". I suspect motion or low light or a mix of both is causing your refocus and beeping. Easy mode is meant to have a range of operational conditions parameters that compensate for problems that will affect image quality, but this is a compromise setting. The camcorder is trying to balance the formula of vibration, lighting, and focus. Try to select another mode of operation - if no other mode is able to do what you want in the conditions you have to work with it is likely your inadvertent movement is the problem. If you stabilize the camera and it still beeps you probably have too dim of lighting conditions for the camera to have a good exposure.
Digital cameras work similar to film cameras in that they are designed around a given set of parameters - most of which are a fixed range of lighting and minimal movement of the camera. I hope this helps you.
SOURCE: "remove tape"
I've had my GL-2 for about 3 years, and just recently started experiencing this problem. It happens when I flip the power saver switch off, then back on again. I've found that removing and reinstalling the battery lets me continue without ejecting and inserting the tape. I also just replaced the watch battery but I'm still getting the "eject" message when I use the power saver switch. I'm not looking forward to spending hundreds of dollars, but it "is" quite annoying.
SOURCE: Canon ZR 600 tape won't load
The capstan motor is broken and needs replacement. You could send it in for repair but it wouldn't be cheap.
SOURCE: will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
SOURCE: No sound w/Sony recorded tapes played on Canon zr960
any recordings made from another digital video device may not meet the same specifications to play back correctly in any other brand model unfortunately. some work and some don't
Testimonial: "Thanks for confirming that I was correct in returning the 2nd camcorder!"
SOURCE: I have a Canon Elura 65 mini DV camcorder. When I
I had this problem and I only ejected a cassette. I tried new and old cassettes. Same result as you experienced.
What I did and I again don't condone striking electronics as a means to repair them but, at the advice of another post and having tried everything I could think of, I stuck the bottom of the camcorder with the palm of my hand several times and it worked. I don't know why it worked and it really shouldn't have but it did.
I think the real problem is a cleaning/lubrication and ultimately should see service by a local trusted shop. Try it I had nothing to lose and it worked for me.....
the beeps ate called post
Then what happens does it restart ? or just wont boot up ?
A bit more information please.
Not sure what you mean by 'when the hard drive beeps
does the hard drive start when you turn the laptop on
(at which point a do the beeps occur a single beep isn't unusual) and it stops when you turn the hard drive off - a beep then would be unusual.
I suspect you don't mean that, & if the laptop is working fine otherwise then I wouldn't worry about it or do you mean something else completely?
make sure the ram modules have secure seatings also check all power and data leads attached from motherboard to hard drive the same will apply for your graphics card
hope this helps
