cade = code?
and 96 the code or the year?????????????????????????????
and dyna heavy truck
built 1979 to present, vast forms. what is yours.?????
no engine stated.
my motto:
NO YEAR?
NO MODEL (dyan)
No engine size. (or transmission type A/T or M/T?, if that is in question)
NO HELP (or your joy)
No country , too , is a royal pain , all cars are different by country (laws)
To which network has your nokia 6120 been locked to? You can get the unlock code from the respective network provider or from any trusted vendor online.
I can't give you the code because you didn't give the country and the network provider.
anyway here's DIY method
Here's the way :
* download this link : http://www.uploadmb.com/dw.php?id=1306822616 * extract the file and place it on your desktop * open the application * choose your country and provider * enter your 15 digit imei located at the back of your phone or just type in *#06# * press calculate
just follow the code flashes on screen.preferably 1 & 7 is effective...
No country has the code 96, but middle eastern countries have the following country codes: +960: MV
+961: LB
+962: JO
+963: SY
+964: IQ
+965: KW
+966: SA
+967: YE
+968: OM
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
If it starts out in 2nd gear & dosn't shift, it is probably in a limp in mode. the system will need to be diagnosed & computer satisfied. sometimes disconnecting the battery will reset the computer & allow the trans to shift untill it sees the problem again. I recomend getting the codes read first so the memory will not be erased.
None of country have country code +96. But middle easts' country code starting with +96. +960: MV +961: LB +962: JO +963: SY +964: IQ +965: KW +966: SA +967: YE +968: OM +969: --
p1698 code=No CCD message from TCM or No Transmission Bus Messages It means the person's computer could not connect with yours.it's possible it was his problem if your not having any issues
HAVE SOMEONE EXTRACT THE CODE FROM THE CAR'S COMPUTER. IF THERE IS A CHECK ENGINE LIGHT ON THEN THE PCM HAS A CODE STORED ON IT. IT SOUNDS TO ME LIKE A THROTTLE POSITION SENSOR, BUT JUST CHECK THE CODE TO BE SURE. SOME OF THESE CAN ALSO HAVE A BAD IDLE AIR CONTROL VALVE. I HOPE THIS HELPS YOU TO FIND THE PROBLEM. PLEASE KEEP ME POSTED, THANKS FOR USING FIX-YA. GOOD LUCK
