Kingston Digital DataTraveler 4000 8 GB Flash Drive DT40008GB USB Hard Drive Logo
Posted on Jun 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
Anonymous
Level 3:
President:
  • Master 652 Answers
  • Posted on Jun 01, 2011
Anonymous
Master
Level 3:
President:
Answers
652
Questions
Helped
180091
Points
2174
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
2helpful
2answers
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Write protect erroe give cant not format and copy files in my 8g DT101 data travel plz help me
write protect error give cannot format and copy files in my 4g DT101 data travel plz help me
256mb & 512mb Trek usb thumb drive can't be formatted
As all your pen drive are getting affected by auto.inf virus your PC contains that virus.
Please scan your PC with proper anti virus and clear all your drives in PC.Then insert the pen drive and scan and remove that virus.
The intensity of affecting the pen drive depends on the virus.Hi no virus damage the usb physically.
Please do the above steps and you wont get it again.
Thanx
My pendrive becomes write protected and it's also not formatting.
Insert your pen drive, RUN this tool AMVO-VARIANTS by keeping in any drive , then restart the system without removing pen drive from system , after reboot your pen drive be ok.
1helpful
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
2answers
Newly bought 2GB DataTraveler only show 1GB capacity
Did you read the emanual that is on the Kindston's website for the DataTraveller? When you use the password protection program, it logs you IN to another partition you created when you started it the first time. It logs you off of the  normal drive partition and in to the password protected partition.
Both exist on the same pen drive but can not be accessed at the same time. Try logging off using the same program or if there's such a logoff shortcut anywhere on the pendrive, yo should be back to the normal 2GB partition.
HTH,
Deboo
Pendrive error
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
I
3helpful
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
I cannot format my kingston datatraveler it says its protected
hello evelymont i found a solution to our problem!!try to download HP USB Disk Storage Format Tool and try to formta the flash stick to fat32 file system!!And after that you're ready to store any file you want unless you put them in a folder first because of the fat32 file system and not saving them on the root for exaple if you want to store an avi file at E: where E: is your kingston usb data traveler save the avi like this e:/name of the folder/avi file, and not in the root e:/avi file!!
that 's it !!congrats for your buy!!
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
