Some phone have a system folder on root directory after formatting the memory card on the mobile.Basically,you will see a music folder and all songs are placed their so the phone recognizes the folder everytime the music library automatically updates the songs installed.
When you load the memory card on your computer using a card reader, check the card content if there is any folder installed such as "my music" folder, if the is,try to load music on that folder.Otherwise,just make a new folder and rename it with "my music" or "music" folder.
If you already done on this method and still the phone music library does not see or update the music files, maybe you need to reset your phone to refresh your phone system memory that might be corrupted.By doing this,you need to go on your menu settings then locate the restore factory settings,remember that all files will be deleted if you wish to continue,better back up all your important data first before proceeding,and then it will ask for the lock code and then just enter your desire code or it enter 12345 as the default lock code.
If you have some questions and concerns,please don't hesitate to reply..Thank you.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Dear,
All just try this trick
Connect your phone to PC and try to acces the card on PC. Now format the card
but, take the backup of data before formatting the card. then paste the data back to the card. Note:- Never delete system file.
Regards,
Rakesh Kumar
first of all insert the memory card in your phone then open the memory card through the file manager.Then remove it and connect it to the pc through the card reader.Copy all the software to the Others folder. Insert the memory card once again and switsh on the phone .Go through the file manager and open the others folder of your card. There you will find the copied softwares .Just click on it and it will guide you through the installation
it is because of that you dont install all of these thing correctly. first of all your have to format you memory card on your mobile when you do this the mobile makes folders in the memory card automatically then you store any thing but make sure you put the thing on right folder pictures to images, movies to videos and music to sound
Ok, sorry for the confusion. I'll elaborate it this way. I have a Nokia N70 all the data from memory card got deleted. When I tried to access the card, it said "Memory card corrupted". I tried to format it but it doesn't work. I even connected it to PC but PC doesn't recognise the card. Hope this is clear. Please help!!
buy a new one .but next time when u want to format ,connect to pc suite via pc and then select memory card and delete file by file but never delete an instal program otherwise it will be corrupt again.so if u want to delete instal promgram ,go to tool / application manager and delete it from here.
go to message menu then press options and press settings and come down to other press that and change the memory options to memory card instead of phone memory hope it works
