Hi.
F13 means Bad EEPROM check, which in simple words means bad oven electronic control. The EEPROM is memory a chip mounted on the ERC board (oven control module). When the board detects that the data stored on the EEPROM is not valid you get this message.
Try disconnecting power from circuit breaker for ten minutes. If that does not work, try longer, leaving oven off for few hours. If that does not fix the problem, then the control module must be replaced.
Regards.
Ginko
