Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is
un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=rawIf the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-gHope this helps you solve the problem.
