Question about Bosch Exxcel WFO 2264 Front Load Washer
Bosch Maxx plus WFO 2460 problem with water draining out too quickly on rinse cycle and overflowing from the point where machine hose hooks into plumbing pipe, which is about 60cm above the u-bend. Plumbing seems to be draining OK from adjacent sink but this does not use the same u-bend.
    Top Expert:
  • Bosch Master
  • 54,386 Answers
I had that experience and it turned out to be a clogged sewer line.
Posted on Feb 16, 2018
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Posted on Jul 23, 2008
Anonymous
  • 135 Answers
SOURCE: our model is a bosch maxx plus 5years old front loader
Is it water in the tub that you can see?
Posted on Jul 28, 2008
Anonymous
  • 706 Answers
SOURCE: LG WM2233HW washer plumbing rattle.
Hello Justin,
What you are hearing is what they refer to as "Water Hammer'.. and aside from the noise.. it probably won't do much damage however home improvement stores such as Home Deot and Lowes sell add on devices that are installed onto your supply lines to absorb the shock when water is cycled on and off... You'll need to tell them exactly what size pipe you have and ( depending on how familiar you are with plumbing) you may want to hire a plumber to install.. They may have a water hammer add on that fits onto the screw on water lines.. Hope this helps..
Posted on Sep 21, 2008
Anonymous
SOURCE: Bosch Maxx WFL2260
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Posted on Jul 14, 2009
Anonymous
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
Bosch maxx plus wfo 2260 will not spin it is working fine up until it is time for the spin cycle. Sometimes I have to stop the washer then just put it on to the spin cycle sometimes this works sometimes it...
Sounds like it is not rinsing properly.
If you have not already done so, then check the pump filter.
This is located at the bottom front right of basher behind drop down cover.
Unscrew anti-clockwise to remove and clean.
Mar 25, 2010 | Bosch Washing Machines
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
HI,
vijay
Oct 04, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Delicate cycle stopped on rinse
Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 02, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Water level sensor faulty
needs must.........you will need to remove lid........look for thin plastic tube coming from bottom of the drum to the top of the drom......connecting on a small plastic unit......this is the pressure sensor.....remove the tube.......blow down it a few times.............might be blocked by grit etc........
cheers
May 27, 2017 | Washing Machines
Bosch Exxcel WFO 2264 Front Load Washer Logo
208 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
