Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
Take
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieive got a 10x10 lawn - _1433.jpgch end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with botive got a 10x10 lawn - _1440.jpgmetal fasteners on the #3 poles facing outwards)
Then connect each end of the combineive got a 10x10 lawn - _1450.jpgo the end piece.
Okay, now wive got a 10x10 lawn - _1451.jpg start adding the actual canopy. Start by pulive got a 10x10 lawn - _1452.jpgcorners down at each pole joint then velcroingive got a 10x10 lawn - _1453.jpg underneath in the middle of the 3-4-3 combineive got a 10x10 lawn - _1454.jpgr />
Now it is safe to connect the next set of polive got a 10x10 lawn - _1456.jpgo the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each polive got a 10x10 lawn - _1460.jpgn connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needeive got a 10x10 lawn - _1464.jpgI tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
The first five pictures were not the ones I loaded. I do not know who these people are or where they are from. Too bad too, because I worked hard on the ones that should be there.
dsponsler
thanks so much the directions and pictures are soooooo helpful!
Thank you so much for taking the time to do this! I struggled with this gazebo most of the day. Then I found your instructions and had it assembled within a half hour!
Thank you so much. I have the screened gazebo which had been in the shed for several years and the directions had been chewed up by some anaimal. I was staring at a box of poles exasperated until I found this post. My numbering was a little different; so the poles went 1 to 1a for top section, 2 to 2a for the sides and 3 to 3a for the legs. But once I reviewed these directions it all became clear. Thanks again.
THANK YOU Dustin! My friend bought this last summer and it did not come with instructions. I was so happy to find this. You did a great job! Thanks!
Thank you!!! This saved me from having a nightmare on my hands!!!
How much was this gazebo?
Yes, type in: ..gazebo manuals and your brand in the search engine of your browser and the page that comes up should display your gazebos brand model. Click on it and tada! You should be looking at the printable manual.
