Thanks for choosing Fixya and welcome to the site. You need to check your fuel pump fuse, relay, and if you have one, the fuel pump reset button. If all of these check out, you will probably need to check the fuel pump. The pump may be bad or something may be killing it. It may only be getting the signal for a second or two. Check those first and get back with me.
Low on freon,or the expansion valve is bad,try adding freon to the system,if the compressor stops cycling,then that is the problem,if this was helpful,please rate,thank you.
shut down the computer start it again press F8 immediatly and keep pressing untill menu appears highlight on "enable VGA mode" and press enter, your problem will be solved
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
