Question about Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram somwhere. Esa Viirret
    New Friend:
Ibanez V72ECE hey i bought new ibanez and the tuner not working, i bought new batteries but still cant run. maybe its some way to activate it or its just bad one? rzepa181@yahoo.com plx helpme
Posted on Nov 27, 2012
  • Ibanez Master
  • 5,603 Answers
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
Posted on May 30, 2011
Anonymous
SOURCE:
Ibanez Pre amp problem
It sounds like the guitar pickup may be faulty. It may be a loose connection on the which could be soldered easily or it may be damaged in some other way.
As this is isolated with your G string, I suspect the individual pickup unit is at fault.
Apr 16, 2014 | Ibanez Music
Hi, I have a problem with my ibanez ew20ase preamp tuner, it was working fine yesterday, now today it doesn't turn on at all, I've tried new batteries but to no avail, also, when I amp it up, preamp works...
I can't seem to find info on this preamp but, that sounds like a power supply problem, considering, the tuner is the part of the circuit that would need power. Volume and tone controls don't, unless they are active,(which I've never seen a reason for). I would try a new battery, because I think you left it on overnight, check the slot for corrosion or a loose wire or connection.
Dec 02, 2013 | Music
My ibanez Ael20 works for 2 seconds when plugged in and than stops working. I have replaced the batteries.
Make sure you are using a TS type cable (standard guitar cable, not balanced). Make sure the tuner is off as there are modes for tuning that kill the outgoing audio during tuning.
Jun 23, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Hi! My TP-4T preamp on my Takamine EG124C works only when tuner is ON. After tuner automaticallt turnes off, the sound stops. Please help!
Hello,I am a guitar tech in Nanaimo,BC,Canada and have run into this problem before.Simply replace the Takamine output jack [where the guitar cord goes into] 3 screws and solder,and it will work fine again.The jack has a switching mechanism in it and when it fails it shorts the output out.The jack is available at most Takamine dealers or Allparts http://www.allparts.com/SearchResults.asp?searching=Y&sort=7&search=jack&show=20&page=5
Mar 06, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
No signal, or in and out ,not battery or preamp
This appears to have a built in tuner. When you press the tuner button, that kills all output. Make sure the tuner is OFF to get output.
Feb 26, 2011 | Applause AE148RRB Super Shallow Deluxe...
I have a takemine 523 12 string. recently, the preamp starting flashing arrows up and down, the tuner is inop and can't get sound through the amp. Any suggestions?
I have this same problem. I press the button to turn the tuner on and nothing happens except the arrows on screen flash alternately. There's also no sound from the output
Feb 17, 2011 | Takamine EG523SC12 Cutaway 12-String...
Hello, I have found that Ibanez AEL20 guitars' 5AEQ45F (SRTn) preamp-tuner has a 6V voltage, my AEL20 guitar came with 1,5 V batteries (3V in total). There is no internet source to get the...
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
Feb 16, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hi! My TP-4T preamp works (sound present on AMP) while tuner ON only. After tuner automatic turn-off, sound stoped as well - some noice only. Can I repair such problem myself (I have an experience in...
Feb 03, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Ibanez Ael20e AcousticElectric Guitar with Onboard Tuner Logo
1,531 people viewed this question
Top Ibanez Music Experts
Michial Gueffroy
PickyPrick
Tom Chichester
Are you an Ibanez Music Expert? Answer questions, earn points and help others
