Sound drivers are for the computer motherboard, you will not be able to find driver with SBS 230, as this is the model of the creative speakers you are using.\
If you are using a DELL, HP, Gateway or anyother brand of PC. Go to their website, e.g www.hp.com or www.dell.com.
Click on the drivers and softwares download section, type the model number or product number of your PC. You will find model number or product number on a sticker on the PC or the BIOS or the Invoice. Type the model number, the website will give you option to select the operating system, select the operating system you are using then click on Audio Driver, download and Install it.
Regards,
Shrey
SOURCE: i've lost my Creative SBS
download from
http://www.nodevice.com/driver/company/Creative-Labs.html
hope
one of these will help you
on the home page you should
see a search tab just type in what you are looking for
(be precise)also the
download software finder under that there will be a list place a tick in the
box of any one you want/need
all software windows
software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this
link will provide you with many freeware and share drivers
hope this
helps you
if these packages are not the
right
http://download.cnet.com/2000-20_4.html
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
