Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Posted on May 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not use my time and date stamp - Canon PowerShot SD400 / IXUS 50 Digital Camera
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on May 30, 2011
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1196056
Points
12483
You'll need to change resolution to "Postcard" resolution(1200 pixel width) to activate date/time stamp (look for it in the menus). Unfortunately, that is the only resolution that date time stamp will work in, or show as activated/selectable in your menu.
1helpful
2answers
How do I completely remove the date/time stamp from Canon AS1100 IS so it doesn't show on my photos?
  1. Step 1: Load the image. Open the image that you wish to remove the date stamp from.
  2. Step 2: Select the date/time stamp. Zoom in on the area with the date and time stamp, and then mark it with marker or any other selection tool.
  3. Step 3: Run the restoration process.
https://www.besanttechnologies.com/training-courses/data-science-training-in-bangalore
How do i turn off the date/time stamp?
If you do not want the date and time stamp on future pictures, turn it off:
  1. Press the Menu button.
  2. Use the arrows to:
    1. Select the Setup menu.
    2. Select the Date/Time Stamp feature.
    3. Turn off the Date/Time Stamp feature.
  3. When you are finished, press the OK button.
Apr 02, 2015 • Cameras
1helpful
How do i turn off the date/time stamp on my camera?
2answers
Would like to know how to insert the time and date stamp onto the Canon A710IS please. Thank you
Download any manual about this product by visiting the link bellow. hope it what you looking for.
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a710_is#BrochuresAndManuals
Thanks for using fixya,
May 16, 2011 • Cameras
How do I date stamp photos?
photos are our archives of memories but sometime we do forget the taken date of an image. Sometime we feel a need of exact date and time the image was taken. The available meta data of an image not always give us good result and we need to be somewhat techie to understand that. So, to keep thing simple it will be great idea to put a date-time stamp on it.
photo date-stamp helps you here. It allows you to put date-time stamp in an image as well as a batch of images. You can choose color, font and font size to style the time stamp. It also allows you to chose the stamp position such as Top Left, Top Right, Bottom Left and Bottom Right.....
thanks.
4helpful
How can I take off the date stamp on pictures? my
Follow these steps:
  2. Select the Setup menu.
  3. Select the Date/Time Stamp feature.
  4. Turn off the Date/Time Stamp feature.
  5. Press the OK button.
If you find my solution helpful, you're kindly requested to rate it. Thanks!
1helpful
Date stamp
To set date stamp follow the instruction:-
1) Press MENU button. 2) Select REC Menu. 3) Use the up and down buttons to Select Date Stamp. 4) Toggle to the desired opetion OFF or ON.
Note:- Ensure the date & time is set before using date stamp function.
Good Luck
6helpful
How do I turn off the date and time stamp on my canon powershot sx110?
The menu on the camera controls the date and time stamp. Turn on the menu i camera mode, there are three choices, Camera, Settings and customize. Time stamp should be in the middle menu. Look for time settings and turn it off. All pictures have time and date always. The time/date stamp just makes it visible in the image.
3helpful
2answers
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
9helpful
2answers
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
