Yes. In your watch, as with most wristwatches that have a snap-fit case back, there's a thin neoprene gasket that sits either in a groove cast into the watch case or around the part of the case back that snaps into the watch case. Either way, the gasket is designed to further reduce the amount of moisture that can wick in between the tiny gap between the case back and the watch body.
As a matter of procedure, for maximum water resistance, this gasket is supposed to be changed every time the watch is opened (for example, when the battery is replaced). As a practical matter, however, I have often reused a gasket if it has not been distorted from pressure or mis-installation (lots of these gaskets end up crimped or pinched when they slip out of position as the case back is pressed into place). Does it provide reduced water resistance? Possibly, though moisture more often enters a watch fastest through the opening for the stem used to set the time. Leaving the back gasket out entirely, however, definitely creates an easy path for sweat and moisture to enter a watch.
