Hello &
Welcome to FixYa Kevin
The problem is with the float switch assembly
that is bad and needs replacement. A float switch
on a dishwasher is designed for one thing, to stop the water flow from the
dishwashers water valve. To access the dishwasher float switch regardless
of the make or model, 99% of dishwashers are accessed from behind the toe kick
panel i.e by removing the front bottom access panel. When the timer or main control call for
water, power is sent through the float switch wires, when the dishwasher has
filled up raising the plastic mushroom looking piece high enough, the switch
will stop power from getting to the water valve. That is the idea behind the
switch, to further test this switch with a volt meter you can view this video:
Please get back to me if you have any other
questions.
Sorry, but have you even tried the solution, if not then at least try it first. If you don't like the solution then try to reset the unit, to do this press and hold the HEATED DRY/AIR DRY/RINSE ONLY button for 20 seconds. If this will not work then try the first solution, again if you don't want to try that one then the problem is with the control board that is bad and needs replacement.
Kevin:
This solution isn't one that's going to help because the dishwasher basically skips the minutes 2-118 out of the 2 hour circuit. The display on the front of the dishwasher goes from "2H" (which appears when the normal cycle starts) to "2" indicating there's only 2 minutes left in the cycle.
Not sure how the solution you provided me helps me trouble shoot my problem. Any guidance or a new solution is greatly appreciated...........Jon
