Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution: I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again. Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times. Print the test page to see how it's look and way you go. Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cat ridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Try to remove the Ink Cartridge while printer is on then install it back after a minute. If you still getting the same error, possible the Ink Cartridge or Printer is faulty.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again.. or 2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Seen this lots with dell printers. Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again.. or 2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
ERROR 1203 LEXMARKERROR 1200Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
