Here are the steps to install your printer.
1. With your computer off. attach one end of your USB cord or communication cable to your computer and the other end to your printer.
2. Plug in your printer to the electric socket and turn on. Wait for it to run through its cycles
and then install the ink cartridges. Also install blank paper.
3. Turn on your computer, wait for it to boot up, and then insert the driver installation disc into
the CD ROM drive. If the disc is unavailable, you can download the software from
http://www.epson.com.ph/epson_philippines/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_T10 and install the print drivers in this method.
4. The disc may give you certain instructions to follow when installing the printer, be sure
to follow them.
5. Your printer may automatically print a test page after installation, if it does not, you may
want to print one to check the proper operation of your printer.
Hopefully, you have installed the printer correctly and have no problems. If all does not go well
check all connections to the printer as well as those to the computer. Check the ink
cartridges for proper installation and re-install the drivers, if necessary.
