Master
- Posted on May 29, 2011
Re: When ignition turned to on a loud clicking coming...
Sounds like a temp door actuator. Does the heater controls move to all positions and change from hot to cold.
Testimonial: "thank i puilled the air con. fuses and problem disappeared and when the 10 amp fuse was reinserted problem came back so i am going with the actuator a"
thanks once again removed air con. fuses and problem solved .Put back one fuse starting with the 30 amp then 15 and problem came back when 10 amp installed so i will be going to part store to get a new actuator .plus tthis is the only vehicle i do not have a shop manual for so that is on the top of my list thanks again for info .John
