Craftsman 42" Briggs Stratton 20 hp Gas Powered Riding Lawn Tractor Logo
Posted on Feb 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Craftsman 42"Lawn tractor - Mower
Bill Boyd
Level 3:
Top Expert:
  • Craftsman Master 53,816 Answers
  • Posted on Feb 14, 2018
Bill Boyd
Craftsman Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11935230
Points
172802
Jammed cable from rust or broken strands
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on May 18, 2009
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Anonymous
  • 57 Answers
  • Posted on May 19, 2009
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jun 08, 2009
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
panilling9
panilling9
  • 284 Answers
  • Posted on Jun 09, 2009
SOURCE: Looking for manual for Craftsman 917.256552 15HP
if you go to sears.com click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
Anonymous
  • 130 Answers
  • Posted on Jul 22, 2009
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 • Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
I have a LT2000 21 HP lawn mower. The mower is brand new, just put gas in it today. I can't get the mower blades to engage without shutting the mower off. I have tried it in neutral, forward, sitting...
Hi, Have you tried to turn the blades by hand ( WITH THE MOTOR OFF ) I suspect there may be some transit packing that you may have missed. The blades should turn freely with the motor off and the blade engaged. There is a blade brake which stops the blades turning when the drive is disengaged which might need adjusting .
Hope this helps.
Blades on my Sears Craftsman riding 42 inch lawn mower will not disengage.
It might be that a drive belt is too small and doesn't release. It would be where the power goes from the engine to the deck.May have to get bigger belt.
4helpful
2answers
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
1helpful
Blades will not disengage
the brakes on the deck belt not working belt to tight or deck not fully disengaging
Cutting blades won't disengage
Check you blades to see if one is bent. Do this with the mower NOT RUNNING and the KEY OUT of THE IGNITION! Look under the deck to see if one is bent. This will cause the wobble. As far as no disengaging your electric clutch could be bad. The bearing could have seized up.
1helpful
I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
1helpful
Mower shuts off when clutch is disengaged.
Check your seat adjustment to make sure you're applying constant pressure to the safety switch under the seat.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
