This link will help you!copy and paste this in your browser's main address bar and hit enter
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257147&cc=us&lc=en&dlc=en&product=391153&tmp_track_link=ot_search
or
on the printer control panel,press the setup menu (wrench button),then push righ arrow to go tools ,push ok then select display estimated ink levels,push ok.
SOURCE: HP Officejet 7210 All-in-one
TRY TO MOVE YOUR CARRIAGE, IF YOU CANT THEN CLICK ON THE LINK BELOW:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&cc=us&lc=en&dlc=en&product=391153&dlc=en&lang=en
or this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00295211&cc=us&lc=en&dlc=en&product=391153&dlc=en&lang=en
Post here if its solved or not
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
SOURCE: how do I check the ink level of my HP Officejet 6300 series?
only wy to check levels is to install the software that is part of the printer it will give you ink levels as they go down
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contactscheckthis link for idea to clean the head.
http://www.youtube.com/watch?v=LGPCjKzRtBk
