SOURCE: Beeping Ice Machine
the beeping is a fault code i need to know how many beeps it does before it starts over Also you can shut down the pwr this will reset it but if you dont fix the fault it will return
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
SOURCE: hoshizaki ice machine repair?
is water pump running? is sufficient water in the sump? they harvest when the harvest thermistor says lines are cold. lack of water and the thermistor gets to cold to quick and a premature harvest. no water or pump over plate and it gets to cold to quick. the water over the plate keeps temps up till ice can form. good luck.
SOURCE: Ice machine is only making flakey size ice.
sounds like there is a problem with the water in the sump escaping. Sometimes, the plastic grate under the evap plates break and pieces get stuck in the dump valve. It is a triangular piece that the pump attaches to via a hose. It is spring loaded and the pieces prevent it from seating, thus, water leaks into the drain that you will not notice. When the water level in the sump gets low enough, it goes into a harvest and drops small slivers of ice. I'd check that out first.
Hope this helps.
