HI, sorry to hear that...
Basically, if that happens the LCD of your phone is busted. make sure the battery is working also try to use that battery to another phone if does not working that's the time that you have to visit one of your service center in your area...
Thanks
SOURCE: SGH G600
This happened to my old phone...try opening up the back and just move the sim card in/out/around (depending on phone)...then retry starting it up...it didnt fix the problem but every 5 times i had to do this....hopefully this will work...gd luck
lilolo
SOURCE: Sanyo 6600 fully charged battery but wont turn on
just simply take the battery out and the phone will shut off. You will not lose any contacts or other memory as long as the phone is on idle
SOURCE: Nokia 6500slide screen fades to black and white then offs
Its a Virus Problem CommWarrior.
Format Ur Mobile.
SOURCE: phone turns on and off but wont start
try using ur phone while plugged in charging. if it works thn ur battery defective
SOURCE: Sony Ericsson W910i wont charge or turn on?
i had the same problem, just recently discovered that if i plug the charger connector into the phone and bent it back at an angle towards the back of the phone(slightly, not much) that a red light would switch on on the buttons(strange). But anyways it would start working again then, dont shoot me tho if it doesnt work for you guys
