SOURCE: how do i locate and replace the blower motor on # 58ZAV096
not sure if you have fixed the problem. There is a web site to get this motor... www.arnoldservice .com he should have the motor. I recomend a generic 3 speed mtr. you will have to cut the plug on the original as it may be a 4 speed but you only need 3 speeds. The oem motor will be more expensive then an aftermarket.
SOURCE: CARRIER WEATHERMAKER 8000.NOT SURE HOW OLD. HAVE
sounds like the roll out switch may be sensing a clog. here is a website that can explain things better, hope it helps Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
