I had a guy take the fuse out of my tv to "replace it" for me but he never showed back up! I need to buy a fuse for my PS27113 but need to know what size. Help please! :)
The Proscan brand was licenses to ONCorp. Thomson/RCA does not sell them anymore.http://proscanus.com/default.asp?mn=4&id=infor You can call them and they may be able to direct you to where you can get the user guide/owners manual.
You can find many remotes for these TV's all over the net... just do a search. RCA universal remotes will also work. Generic Universal Remotes will also work... just make sure they have the function keys that you need for what you do on your TV. (PIP, etc.)
You can tune to 90 for input 1 S-video, 91 for input 1 composite and 92 for input 2 composite only. Most RCA and GE brand replacement remotes will work using code 000, or 001. I use code 237 for my 5 in 1 remote and can get PIP and the setup displays to work. tom
Do you still have the original fuse? There is numbering on there that shows the specifications. You probably need a slo-blo type fuse, 3A or so, but I can't be sure on that.
Good day. Try to check for the prescence of 160volts along the secondary output. Also check H out transistor and likewise, loose contacts along the chroma ic
I used the remote control code of "69" for Thompson which makes GE & RCA according to another post. This worked to program the remote of my GO Video DVD-VCR for the TV
Hi. What you need to do is plug in a cable or Antena in its place, and reprogram the channels. if you did that, then try to use a VCR or DVD player and install it using the RCA cables. Install the cable to the DVD or the VCR. If nothing works, My TV has a crack in the LCD. I'll either sell it to you, or buy yours. Let me know. Thanks.... email me to [email protected]
Thank You...
