Haier HDN455 Dehumidifier Logo
Posted on May 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you hook up drain hose to model HDN455 RB
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on May 27, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2103384
Points
14643
Remove the bucket and remove the plastic cap on the bottom of the bucket. Then take the rubber insert out of the cap and save it. You will use it later. Using the hose that came with the unit, thread it through the cap opening and add the washer to the cap. Screw the cap to the mating connector on the bucket. Be sure to use the washer or the connection will leak. Now, thread the hose through the round hole and extend the hose to the back of the unit. And finally, replace the bucket in it's original position in the unit.
Hope this helped you. Please let me know. Thanks.
Where do i hook up the drain hose?
looking at the back of the machine there is a plastic female hose connection just above the top of the reservoir.
Why won't it drain through the hose?
continuous drain option, So was there a plug in the end of pipe, did you remove it, does your pipe run down over, has to. Not a lot between bottom of unit and floor, But pipe has to go down over, if up and down, will not drain. down all the way
Don't see anywhere to hook up hose to the bucket? So that it will continously drain. Model HDN655E-rb
The drain plug should be on the rear of the unit about 1/2 way up the back of the unit. It has a screw off cap and rubber plug. Keep these & don't lose them. You will need them, whenever you stop using the hose drain. Most folks put them in the water bucket for safe keeping.
The garden hose can not exceed 48" in length and slope down and straight to the floor drain. Drainage relies entirely on gravity.
Hope this helps you and thanks for choosing FixYa.
Haier model hdn455 serial number 05021110 it runs but has never taken a drop of water out of the air, so it just keeps running
The problem, may very well be, that the humidity extraction level is set too high. Lower it to 35% and see what happens. Keep in mind, the lower the percentage of the moisture/humidity setting, the more it extracts from the household air. The higher the setting, the less it extracts from the household air.
Also, remove and check the air intake filter to see if that needs to be cleaned. It should be cleaned at least twice a week during the operating season.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
The coil in the back of the my Hairer HDN455 is freezing up.
dehumidifiers work by cooling down so that warm moist air will condense has it stopped working ?
2answers
Hooked up garden hose for continuous mode but it Problem with the Whirlpool AD35USS Dehumidifier Hooked up garden hose for continuous mode but it seems the water is going into the bucket and not through...
First, the hose should not exceed 5 feet in length. There is no pump in that model dehumidifier. It relies totally on gravity to drain through the hose.
If all of the above is as stated above, I suspect that hose or the tubing inside the hose connecting is clogged. Which forces the water into the bucket rather than the hose.
To remove the clog in the unit, you will need an 18" long plastic Zip Tie or something similar, that is appropriately sized to fit into the hose connection/drain hole. NO wire coat hangers though.
Carefully feed the Zip Tie in to the hose connection. About 6" in the tubing will bend. You need to gingerly work the Zip Tie past this bend, until the Zip Tie bottoms out or you run out of Zip Tie to work with. The slowly remove the Zip Tie while rotating it. This will breakup clog. As you near the end of the Zip Tie coming out, be prepared for some water to follow. DO NOT perform any of this while the unit is plugged in to the wall outlet.
Hope this helped you solve the problem, Robert. Please let me know. Thanks.
I have a hamptom bay dehumidifer model # HB40-D i am looking for the tray that you attach a hose to drain
it should be in the same area where you pull the pan out to dump. There should be a hose hook up inside the space where the drain box is.
Haier hdn455 45 pint overflows
Float switch is stuck, has a broken spring or the actuator arm is bent
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
