1rst.- Ran Out Of gas; After Loading The Tank To Apprx. 5 Gal. And Driving For About 1 Mile To The Gas Station....Engine Stopped.........2nd.- Filled About 2 Gal To The Tank,...Still Wont Start................3rd.- Checked, Uninstalled and Installed (Not Replaced) Fuel Filter.....4rth.- Checked (No Sound Out Of Pump When Turning Ing. Switch) And Replaced Relay Pump,..Turned The Ign. Switch To Driving Position And I Heared The Starting Sound Of the F.P. In The Tank...But Very..Very Week...And Still Wont Start......NOTE..\\: Before Problem..Fuel Pump Kept A Noise Distinctive Noise After Starting Eng.; And It Grew Louder For The Most Time I Kept Driving...~~~ PLEASE ADVISE WHAT TO FOLLOW ~~~ APPRECIATE ~~~~ THANK YOU.....
Year make and model ? You may have cooked the pump or picked up some junk from the bottom of the tank, if the fuel pump is in the tank.
Running on less than 1/4 tank is tough on an in-tank pump.
2000 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2000 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2001 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2001 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2002 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2002 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2002 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2003 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2003 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2003 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2004 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2004 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2004 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LS 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LS 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LT 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LT 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe Z71 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe Z71 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LS 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LS 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LT 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LT 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe Z71 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe Z71 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI C - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LS 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LT 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LTZ 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium
Since the Uplanders have the long (front to back) skinny gas tank, with the outlet to the rear; if you run out of gas with the front/nose inclined lower than the rear, then it can take upwards of 5 to 8 gallons to get it started again. It was written up in a GM TSB. Two gallons won't start it. When the gage reads less than 1/2, it's not a good idea to park with the front lower than the rear...unless you carry a full 5 gal. refill. Thank you GM engineering.
Hi ! a easy way to possibly help this is to get a can of sea foam at the parts store and dump it in your tank it may help dissolve any goop that is in there and it helps renew bad gas ,also if this does not help remove your fuel filter and blow through it it may now have gotten a bit gumped up ,not a bad idea if you havnt done that for a few years anyway ,mostly the sea foam should help!
Try replacing the fuel filter first and the primary fuel filter screen in the fuel pump may be dirty also. As for the the one in the gas tank which is a part of the fuel pump, your just going to have to keep the gas tank half full and add some fuel injector cleaner to the gas tank for the next feet fill ups. As for the fuel filter along the frame rail on the drivers side, they have a life of 30,000 miles or 1 year and needs to be replaced within those recommended intervals. Good luck and hope this helps, Note: the gas is what keeps the fuel pump cool, so low fuel in the gad tank will have the fuel pump run hotter causing it to fail prematurely.
Put the gas in the tank, let everything settle, turn key off, then back on to on position, but NOT start. Let the fuel relay engage the pump and draw some gas pressure. Give it a good minute and it'll start right up.
