Aastra Telecom Aastra MDC Centrex Telephone Logo
Posted on Sep 23, 2017
Nortel Networks Telephone Nortel Meridian M5316 NT Posted by ilgen2 on Jan 27th, 2009 at 2:47pm Display Problem The display does not show anything when the phone is on hook, however the display is fine when you go thru menu items. Is there a display on / off setting that I am over looking? My other phone displays the time and date while hung up. Thanks.
4 Related Answers
Anonymous
  • 38 Answers
  • Posted on Feb 17, 2008
SOURCE: Do I need a network?
If that model phone has a rj14 jack ( standard phone jack) and when you plug it into a known good wall jack and you can draw dial tone then it will work. If not it requires a KSU to interface with the lines and that's a lot more equipment than you need for 1 or 2 lines. Thank you. Jer
Anonymous
  • 192 Answers
  • Posted on Mar 25, 2009
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Anonymous
  • 18 Answers
  • Posted on Oct 01, 2009
Feature *1, Press the desired key, dial the #
Anonymous
  • 104 Answers
  • Posted on Jun 08, 2010
SOURCE: how to download a manual of NT9K16AC35
Click here to download the manual from Nortel for your model
Testimonial: "FixYa, it's very good. thanks a lot."
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
The phone display window is blank but the phone works any suggestions for turing that on?
your phone's LCD display is defective and it should be changed. I have a similar problem but till it works that way, I can live with it. Actually I have 3 more with good display - hehe....
If annoys you, get a used one from Amazon for 44 USD
http://www.amazon.com/Nortel-Meridian-M7208-Telephone-Gray/dp/B0018JVOP2
Sending it to repair might cost you more.
1helpful
3answers
How do I program the T7208 telephone to display incoming telephone numbers?
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
1helpful
Trying to change the number of rings before my phone goes to Voice Mail on the Meridian (Nortel) M5316. Only two rings currently so I miss a lot of calls. Thanks!
Depending what system your provider is using it can either be done by you at home or they will have to set it. If you call your provider they will help you or they will fix it. Each ring is set at 6 second intervals so if you have 3rings that is 18 seconds. If you was 6 rings then ask for 36 seconds etc. hope this helps
Does the phone run on batteries
The phone can get some power from the loop like a basic telephone. That should suffice to make phone calls.
But many of the advance features and display options cannot work on loop power alone. You have to get a special plug that plugs into the wall AND the phone jack. Then plug the phone into that.
I am not aware of any battery in the phone.
Message light keeps flashing on my Meridian M2616 phone after I have checked the messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
I can't log into my Nortel vm account
Change the administrator password by pressing Feature 985 dial 9 even though it is not listed as an option. The display will show Pswd: dial 73738767793. The display will show Reset pswd? Press YES. Now you can log into the voice mail system administrator using Feature 983 and the password 1020000 if you have 3 digit extension numbers. Add or delete the 0 between the 1 & 2 depending if you have 2 digit or 4 digit extension numbers.
Denied access on Nortel T7316E Log# 1020000 will not work..How do I fix this?
Follow this instructions to reset the Administrator password.
Press Feature 985 and dial 9 even though it is not listed as an option.
You should now be able to enter the default password.
2 digit extensions use 120000
3 digit extensions use 1020000
4 digit extensions use 10020000
3helpful
2answers
2answers
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
