Have you replaced the lamp?? You usually have to replace the lamps around every two to three years. The manufacturer has designed it so you the customer could change it yourself without a technicion. Hope this helps.
Have not replaced the lamp, but the lamp indicator is not lit, so it should be ok. I am suspecting the "Green Light of Death" problem, ie capacitors on the DM have gone bad, but I would like to find more info on it before I try to fix it!
Thanks for your post!
