Anonymous Posted on May 24, 2011
Anyone know how to change the decimal place on a ti BA II , not a BA II plus? there is no function ket on a ba II
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on May 24, 2011
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671645
Points
21595
The TI BA-II Executive Business Analyst (maybe not your model) has a key labeled FIX. It is in the middle of the topmost row of keys. Press the FIX key followed by the number of decimal digits you want.
1helpful
Have a TI BA11 calculator that isn't showing decimal numbers. How do I fix it
  1. Press the 2nd button.3
  2. Press the Format button. (This is the second function on the . button).4
  3. Enter the number of decimal places to show 0-9.5
  4. Press the Enter button.
7helpful
How do i fix the rounding of decimal points to not be rounded on my ti BA II plus?
Press 2nd [FORMAT], type a digit representing the number of digits you want after the decimal point (or 9 for floating), then press ENTER 2nd [QUIT].
7helpful
No decimal display on TI BA-II calculator
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
5helpful
Default decimal settings
2answers
2answers
How to change the decimal point
Hi - You can download the manual from the following link:
TI BA II Plus
4answers
SETTING UP THE DECIMAL ON NEW 210 TM
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
