Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
Posted on May 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The washer knob came off and broke. If I use pliers I can spin the timer and the machine will run. Can I just buy a new knob, if so what is the part number
Stephen Lam
Level 3:
President:
  • Master 670 Answers
  • Posted on May 24, 2011
Stephen Lam
Master
Level 3:
President:
Answers
670
Questions
Helped
251920
Points
2115
You can buy a new knob. Try http://www.appliancepartspros.com. The washer timer knob part number is AP2106210. Hope this helps you.
1helpful
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
1helpful
General Electric WHDSR209DWW Top Load Washer. Timer works but has lost proper synch with knob and skirt. Can force timer to a position that will run the machine from an unknown starting point. When knob...
Hello:
Its either your knob is stripped or the timer itself is..Most commonly its the knob assembly that's bad.(part# WH01X10061) I would try it first since the knob is only around $7.00 where the timer is around $140.00or so...
Good luck
1helpful
We have a Maytag toploading washer (SAV4655AWW). The stem holding the knob for the water level broke off. I think I need to replace the entire switch. Is this something I can do myself?
Yes you can do it.
For now just turn it with a plier until you buy a new knob or get one from another washer machine go to the lockal repair shoppe or the salvage place to get a replacement.
Vitally
5helpful
2answers
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Timer knob on washer broke off leaving the plastic sleeve attache
I did fix this problem myself, I found a heavy duty 'bread tie' type of wire, I tied it around the base of the stuck sleeve and wrapped the loose end of the 'bread tie' around my pliers and pulled very hard and it shot off like a bullet, I am now using my replacement knob..yeah for me..
Timer knob
HI. the timer mechanism has failed. these timer control modules will run about 134.00. simply replacing this timer will fix your issue.
1helpful
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
1helpful
Washer control knob just spins
The knob is prob stripped, very common for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it. So easy you won't believe it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
