Question about E-Machines eMachines Desktop PC
Can't find my startup disc for my emachine, is
    Scholar:
    New Friend:
  • 57 Answers
Restart the computer as soon as you seed the eMachine logo start tapping on F8.
You will have the Windows advanced option: there is must be repair your computer or system recovery option.
Select system recovery if there is then just follow the instruction.
or else
select "Repair your computer" just follow the instruction when you have the option to select "System Restore" on System Recovery Tools option click on it then just follow the instruction.
Posted on May 23, 2011
    Master:
  • 328 Answers
Yes windows xp potable CD will solve it but select boot from CD ROM rather boot from floppy disk or you can use windows xp on bootable flash memory or you can restore your windows it might work
6ya staff
SOURCE:
Emachines el120006w momitor quits displaying shortly after startup or won't even display after startup
Try another monitor, reseat ALL monitor cables .If you have a Graphics Card, shut down computer, unplug and reseat Graphics Card.
Dec 15, 2012 | eMachines EL1200 PC Desktop
System disks startup
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Nov 12, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
Kenapa pada saat penginstalan laptop muncul tulisan BOOTMGR is compressed..?
google translate
why at the time of installation the laptop it says BOOTMGR is compressed
How to Create a Windows 7 System Repair Disc:
or
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
bootrec.exe /fixmbr
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
hope this helps
Aug 09, 2012 | Computers & Internet
How do you restore a emachines el1200 desk top to factory settings
[1]
reinstalling the operating system If you can run Windows...1 Click (Start), All Programs, eMachines, then click eMachines Recovery Management. eMachines Recovery Management opens. 2 Click the Restore tab, then click Restore system to factory default. The Confirm Restoration dialog box opens. 3 Follow the on-screen instructions to finish.
[2]
If you cannot run Windows...1 Restart your computer, then press the ALT+F10 keys during startup. 2 Follow the on-screen instructions to finish. IMPORTANT • • If your hard drive has failed and you can't restore the software from the hard drive or recovery discs, contact eMachines Customer Care for help. After you restore your computer, it will appear with the same files and programs it had when it shipped from the factory. You still need to download Windows updates and antivirus updates to bring your computer's software up to date.
Aug 27, 2011 | E-Machines eMachines Desktop PC
Emachines 3240 windows xp home edition need to reset to factory settings no disc
Did this come with a recovery disc and you lost it? If it didn't come with one you may have a recovery partition that you can boot to. If there IS a recovery partition you should see a message on bootup that will tell you what button to push to startup to the recovery partition. If you DON'T have a recovery partition your only options are a clean install with a Windows installation disc or to call emachines (gateway) to see if they have a disc to send you.
You can contact them by following the instructions here:
http://secure3.tx.acer.com/findsystem/FindSystem.aspx?title=Contact+Support&brand=eMachines
Aug 10, 2011 | Computers & Internet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
My Emachine with Windows Vista keeps shutting itself down? What could be the problem?
The first step would be to turn off automatic restart on BSOD errors.
  1. Click on Start and then Control Panel.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel you won't see this link. Simply double-click on the System icon and proceed to Step 4.
  3. Click on the System link.
  4. In the task pane on the left, click the Advanced system settings link.
  5. Locate the Startup and Recovery area and click on the Settings button.
  6. In the Startup and Recovery window, locate and uncheck the check box next to Automatically restart.
  7. Click OK in the Startup and Recovery window.
  8. Click OK in the System Properties window.
  9. You can now close the System window.
  10. From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
Now when it errors it wont restart, instead it will give you an error message that we can use to troubleshoot your problem.
I hope this helps! If this did help you, please give a thumbs up!
Jun 28, 2011 | E-Machines eMachines Desktop PC
Accessing EMachines W3107 Recovery Partion
You can fix this virus without recovering.
Log in normally. Go to run, type in msconfig and go to the startup tab. Uncheck everything and reboot your pc. Once there try your internet. If it's not working go to Internet Options, Connections, Lan Settings, and uncheck anything in your proxy settings. Close IE and reopen. You should be able to connect. Then download and run Malwarebytes, and then run Bitdefender Online scanner.
The only other thing that may be trouble is that there may be a rootkit that neither scanner will detect. You can run Combofix, but this program isn't for the average user. Follow instructions carefully when using Combofix.
Mar 23, 2009 | E-Machines eMachines Desktop PC
How do i get the setup disc or dvds?
Found other question....
The setup dvd is usually made when U turn the pc on for the first time. The system will want U to make them them called Recovery disks (dvd's).
Must be used machine and needs some TLC.
After shutdown, unplugged, open case and vacuum or blow out dirt. Clean fans and gently push connections to insure good connections. Power up to make sure all fans are working. Unplug and reassemble.
Boot up and run Disk Cleanup, then Defrag. Run MSconfig - startup tab and uncheck everything. Reboot.
The only thing that will shut down pc is overheating. If confussed, go to control panel to power options and read options, set accordingly.
U can create recovery disk by following directions in the Help and Support section.
Good Luck
Apr 02, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
E-Machines eMachines Desktop PC Logo
270 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
