SOURCE: ethernet drivers ibm 8187 thinkcentre m50
No, this is a SCAM advert. Driver Detective is a con. They are charging you for a FREE driver available on the net. CON CON CON!!!!
SOURCE: IBM ThinkCentre S51 Intel Pentium 4 PC Desktop
Sounds like it's probably the power supply. The computer takes more power to boot up than to run, so if it can't get enough wattage it can't boot all the way up, and it will shut down and try again.
If you're comfortable opening your computer up, you can test the power supply connectors with a voltmeter or multimeter to verify. A new power supply is typically only $30 or $40.
Testimonial: "Thanks a million! I suspected it was something related, but having just purchased the computer from Tiger Direct, I was under the impression that all equipment was properly tested and verified to be in working condition. I will simply return and have them ship out another. Thanks again! DC"
SOURCE: IBM Thinkcentre M51 - 8141 - 23U -Fresh install XP
try this link:
http://www-307.ibm.com/pc/support/site.wss/MIGR-58254.html
