Check on the utility tray where your charger cord plugs into the rear of the chair it should be on the far left side of the tray near the amp meter Hope this helps
Testimonial: "Thanks for the help, but the problem was the controler buttons not closing the circuit. Thanks"
If the chair has been through rain, snow, or anything like that, it will malfunction which then you'll have to call the company and bargain what you can do. If that's not the case, make sure you check all electrical connections and also all controller connections. If everything is where it's suppose to be, then try hitting the circuit breaker switch, which is between the meter and the charger receptacle. After that, turn on the controller. If it still doesn't work, contact the company. They're normally helpful with giving advice on the possible problem. Good luck! :]
