This error (e 001) generally occurrs when your graphic card is not supporting FIFA 11. This issue can't be removed unless you get a better graphic card.
If you want a better graphic card, you can consult THIS website.
I hope I helped you! Thank you for using FixYa!
Just run it again, if it's still show E001, try to delete it and download it again it will work soon, good luck to you.
by the way, you may need lots of fifa coins to make your team stronger, cheap fut coins can be bought on https://www.fifacoinszone.com?aff=93749, good luck
