Proscan 26LA30Q 26 in. LCD Television Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my tv when turned on shows a half red and half blue light when turned on the picture is multi colored any idea what is wrong ive turned it off and on and unplugged it any ideas thanks Todd
Anonymous
Level 3:
  • Proscan Master 2,098 Answers
  • Posted on May 23, 2011
Anonymous
Proscan Master
Level 3:
Answers
2098
Questions
Helped
456479
Points
6457
Hi Todd,
This kind of symptoms indicated of LCD controller board malfunction. First isolate the unit from loose connection inside because it will do same symptoms. Take it apart and pull-out the cable connectors from the LCD controller board, power supply board, and main board, inspect and then re-insert and ensure the connections.
If the symptoms still persist check the supply voltage in the LCD Controller board if present. If yes, this is an indication that the power supply is not the issue but the controller board. You must replaced this board to back the unit in normal operation.
If the supply voltage is not present in this board, your power supply output has a problem and disable the controller board. You must check this board from faulty parts like open fusible resistor(low resistance value), open/shorted regulator transistor/Zener diode, bad solder joints in line with the supply voltage (crack/dried/cold solder).
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the faulty parts.
Also check if your unit is under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
3answers
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
I own a color TV 29 '' model CM29 FS1 The color display on the screen shows Multi-colors instead of plain Blue. The Multi colors continued to remain on display even when the picture on the TV / DVD comes...
Hi! the problem you have describe denotes that you have a defective positive thermistor. the positive thermistor is the one responsible in turning on the degaussing coil to align the stray color on the picture tube during start-up.
1helpful
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
Hi my tv turns on but just shows a blue screen and the sensor light flashes red there is no picture or sound ive tried switching it of from the mains plug sky tv in and another dvd player but no good any...
try the av buttons on your remote, see if it switches to ur external box.
if that doesnt work, try a s-video (and rca audio cables) to scart adaptor (with those mensioned cables)
from the box, if that works, could be something to do with the scart?
or could be a av issue,
PANASONIC PTK-4077S PROJECTION
You need to adjust screen drives on Red Green Blue tubes ,does all 3 of them light up? Focus/screen control box is in front of TV behind front panel Turn color off then adjust all 3 tubes to where you have a black and white looking picture, now turn color back on.
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Help
Sounds like a blown fuse in the power supply
2answers
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
