SOURCE: I can't boot from CD. Can't boot previously installed OS
Hi, Make sure that you set the POST first boot to CD. If the disk is a bootable disc, you should be able to boot from the CD. If you have any questions, please feel free to contact me ASAP. Thanks, Mike
SOURCE: Only the cpu fan spins
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
If I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard lights are out and (wonder!) I can start the computer again in a normal way.
Can this one be a temporally solution for you too?
I guess that can be electricity dysfunction of a wrong fixed cable.
SOURCE: Biostar GF 7100-M7 windows xp trouble
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
SOURCE: i need sound,vga drivers for biostar k8m800 micro am2 motherboard
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=141
There u go! all the drivers there is for that mobo!
Good luck
Dont forget to RATE me
Nic
SOURCE: gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
