Jason,
AMAZON no hits.
A eBay check for:
lt2030u gateway display ribbon cable (and)
lt2030u gateway LCD ribbon cable NO HITS!
Then I tried hunting for:GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREENS and found this part number for the SCREEN: Gateway F846431 hoping to track down a supplier? NO HITS there either!
My final recommendation? Go to eBay and look for Auctions:
352215358996
122852779509
Now go to the bottom and "Ask buyers and sellers about this product"... MESSAGE the guy OR ~ CALL him at:
(201) 830-1637
between 11:00 Am - 6:00 Pm ET
Monday through Friday (excl holidays)
MAYBE they have your cable?
Anthony
GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREEN 10 1 WSVGA...
SOURCE: Gateway left hinge broke
Not a very hard thing to do. Should buy in pairs. Here is one place that has them for sale.
http://www.mundocorp.com/shopexd.asp?id=6655
SOURCE: My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: Hi my Gateway M405 's backlight goes out randomly.
it's the backlight on/off switch going out
Testimonial: "Thanks for the tip,now I have a direction to go!"
SOURCE: replacing the keyboard
This is the link to the R4000 (and ZV6000) Maintenance and Service Manual. It has detailed instructions on how to disassemble and repair the computers.
http://h10032.www1.hp.com/ctg/Manual/c00364919.pdf
Hope it helps!
sdw
SOURCE: just need instructions on how to replace lcd
If you have to ask "how", I recommend that you STOP, and take the computer to a qualified technician, to have the work done safely & correctly.
