Samsung BD-P1600 Blu-ray Disc Player Logo
Posted on May 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung BD-P1600 will play a SD disc but the rental Bluray discs won't play. Is there any way to reset the player? THX.
Kristine
Level 2:
Sergeant:
  • Samsung Expert 294 Answers
  • Posted on Feb 26, 2020
Kristine
Samsung Expert
Level 2:
Sergeant:
Answers
294
Questions
0
Helped
171792
Points
904
Maybe the rental Blu-ray disc is a copy one from a protected Blu-ray disc. You can return the disc to the owner or you can just simply remove the protection using some tools such as Leawo Blu-ray Cinavia Removal This tool is able to remove protection like cinavia and other protections such as AACS.
Anonymous
Level 3:
  • Master 1,116 Answers
  • Posted on May 22, 2011
Anonymous
Master
Level 3:
Answers
1116
Questions
0
Helped
528019
Points
3536
It is not the player you need to reset, it is the rental DVD's. They are encrypted with a code to limit the amount of time they can be watched, thereby protecting them from being stolen or not returned. Send them back to the rental company and rent the same movies again. That is your only solution. Your player will play whatever is put into it. I hope this helps.
3answers
My samsung bd-p1600 will not play blu ray movies
If it plays other Blue Ray discs OK then either the disc is faulty or it is the wrong region. If it previously played, then my bet is that the disc has a scratch or dirt on it. If you have another blue-ray player or you have a friend with one try it on that or theirs.
2answers
My Samsung Bd-P1400 won't play a bluray movie
Since you have done all the updates then Samsung should replace your model, there is nothing more that can be done until they come up with a solution.
I have been given a Samsung BD-P1600 (xeu) blu ray player.\r\nThe issue it has is no response from the remote(it IS working OK) and the word 'LOAD' on the front and on/off,open /close functions...
try to use a toothpick and put it on the small hole just beside the player so that you could remove/insert discs. Play it manually if the remote did not work...
9helpful
3answers
New Blu-Ray disc won't play on Samsung BD-P1600. It's Disney's "Tangled". I've updated the firmware. The disc loads so you see the Disney castle, and then it stops there. Well, the timer is...
Press the stop button on your controller when you get to the Disney castle, then press the disc menu button on your controller, this should take you to the disc menu and then you can choose play and watch the movie. This worked for me, I was having the same problem, even returned the Bluray disc, got a new one and same thing happened. The same problem is happening with the Tron bluray discs.
2answers
How do I play a movie on my Samsung blue ray without a remote
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc.
2.DISPLAY :Displays the playing status, time, etc.
3.Remote Control Sensor :Detects signals from the remote control.
4.OPEN/CLOSE BUTTON :Opens and closes the disc tray.
5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track.
6.STOP BUTTON :Stops disc playback.
7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback.
8.POWER BUTTON :Turns the Blu-ray Disc Player on and off.
9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected
to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
2answers
Blue ray disc want play in samsung bd p1600
Is your software up to date. If player has old software and you try playing some newer Blurays, it wont play.
2answers
DVD playback distorted in Samsung BD-P1600 Blu-ray Player
i had this problem with mine, found fingerprints on discs, just cleaned the discs and no problem after that.
2answers
My bluray player is a samsung bd-p1500 and terminator salvation the bluray wont play it never even gets to the menu?
All disc players have a thing called stacked tolerance. What it boils down to is some transports in players will not play certain discs; plain and simple.
All you can do it test it out on another BD player to make sure the disc is fine and test another disc in your BD player and make sure it hasn't gone defective.
Sorry I don't have an easy fix, this is not an uncommon problem.
Netflix BluRay disc freezes on samsung 1600
I have had this problem a few times myself with clients players. A power down usually helps but only temporarily.
Check your firmware version and available product upgrade here: http://www.samsung.com/us/consumer/tv-video/blu-ray/blu-ray-players/BD-P1600/XAA/index.idx?pagetype=prd_detail&tab=support
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
