Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
Posted on May 21, 2011
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
  • Bill Allen Sep 18, 2012
    Mine behaves in exactly the same way..... very annoying to have spent out for a premium product and got poundland performance.
Natalie Ford
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2015
Natalie Ford
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1730
Points
I get the same problem, even having bought a brand new battery. :(
lex brooks
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Nov 11, 2011
lex brooks
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
13303
Points
23
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
2answers
I have a Dyson v6 animal handheld and It will not turn in. The indicator light flashes blue one time and then flashes red one time. Iā€™ve searched and searched for a solution but can not seem to find any...
First check it is fully charged. Secondly, Try checking all the pipes, tubes and attachments for blockages. Basically take it to bits and clean it. Dyson have a 'cut out' feature fitted to stop you burning out the motor when it's blocked up.
2answers
My Dyson DC35 stalls. I've thoughly clean it, so it's not a clog problem
1st make sure battery is fully charged.
Next, wash the filter, just follow the instructions in the manual.
If the filter is clogged the motor will try to run but then cut out to protect the motor from damage.
Dyson handheld works for 30 seconds the cuts out
Hi Edward, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson handheld. In order to help further, we would need some additional information about your particular machine, including which Dyson handheld model you own. It would also be beneficial for us to talk you through some quick diagnostic checks when you have your machine fully charged and easily to hand. We should then be able to help you determine which part is at fault.
At your earliest convenience, please give our experts a call - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
5answers
Dyson DC44 Animal Handheld Vacuum, keeps cutting out
dyson-dc44-animal-handheld-vacuum-keeps-ehecv3x4uj13pgwprhzrjmma-4-1.jpgThe battery falls slightly loose, so you have to fasten it securely to the body of the vacuum. I learned this from another user here on Fixya. He uses electric tape. I used one of those rubber bracelets that kids wear. Worked perfectly!
My Dyson DC31 runs for a few seconds then cuts out and won't work at all. It is fully charged. We bought it just over 2 years ago and it has worked perfectly until now. It is clean and has no apparent...
Hi Jean, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC31. If it cuts out in use when it's fully charged, we'd need to take you through some quick diagnostic checks when you have the machine at hand. This will help our experts determine what may be causing the issue.
Please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
http://www.dyson.com
1helpful
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
