SOURCE: my husqvarna 125L weed eater will only run with
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
SOURCE: what is the oil to gas ratio for the husqvarna
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
SOURCE: my Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
SOURCE: when i start my husqvarna
A clogged fuel system or a carburetor in bad need of a rebuild can cause this. Also, if the engine end of the throttle cable has pulled out of the lever on the carburetor, or off of the trigger on the handle, you will have this symptom.
