Tried pushing input and menu buttons and got two blinking lights a pause and two more blinking lights what does this mean. still have no picture turns on but wont stay on
threre is a status light by the power button it keeps blinking red and tv will not turn on hit reset button tv came on then turned back off after 1min.threre is a status light by the power button it keeps blinking red and tv will not turn on hit reset button tv came on then turned back off after 1min.
You can't post conmments that contain an email address.
model 52530 airflow blocked error message, i move it a little and the mrssage goes awaymodel 52530 airflow blocked error message, i move it a little and the mrssage goes away
shop_tech I have a WD-52525 the screen has patches of fuzz while watching the when I pull up the menus theres no fuzz on the menus but still in background they are almost diagonal lines swaying. there is also a ping pong ball size circle that floats up and down on the right side of screen do you know what part is going out would I be able replace myself? do your-self difficulty?shop_tech I have a WD-52525 the screen has patches of fuzz while watching the when I pull up the menus theres no fuzz on the menus but still in background they are almost diagonal lines swaying. there is also a ping pong ball size circle that floats up and down on the right side of screen do you know what part is going out would I be able replace myself? do your-self difficulty?
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
Engage the self diagnostic feature that this set has:
after set shuts off; On front of set push and hold both the Menu and Input buttons in together for 5 seconds and release both buttons.
The power light should blink a two digit error code (it will repeat it about 10 times) for example: two blinks, a pause, and two blinks (this is the most common error code)
Let me know what the error code is and I will tell you what it means
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
