Your Nokia phone was designed with a default security code of 12345.
To change it,
1. Go to 'settings' on your phone.
2. Then 'security'.
3. Then 'access codes'.
4. Then 'change security code'.
5. When you select to change security code,
it would prompt you to enter the security code (initial one, ie. 12345).
6.When you have entered the intial one, it would prompt for the new code.
7. Enter any 5- digtit new code of yours.
8. It would prompt for a confirmation.
9. Re enter the new code.
And your security code is changed. But remember to use number you can easily remember.
Hope that was helpful?
Regards.
I forgot my code number instead of 12 345
Just go to seetings after security seetings after change access codes after change security code and type your security code is 12345 by default and type your new security code
Changing the security code
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed
or
