Master
- Posted on May 20, 2011
Re: We understand that your problem is: sony kf42sx300u....
Good day!
You have a better chances if you have failing capacitors on the power supply section.
Follow this procedure on how to replace the capacitors.
- Remove the back cover of your TV.
- Look for the power supply board.
- After that,look for the leak or bulged on the top capacitors.
- If you found ,replaced it with the same type,ratings and value.
- And finally after you replaced bad capacitors on the board,plug-in your TV and power it ON to test if it is OK.
I hope this solution will be helpful.Thank you and good luck.
