My blackberry 8520 boots & shows uncaught exception 16>=16
app err 523 reset
i want to take a back up please help me
Download and install the following- BBSAK, Blackberry desktop, the firmware for your phone. Run BBSAK, press Wipe phone, wait two minutes. Then close it and open Blackberry desktop, run phone upgrade, wait 40 minutes, then upgrade the applications.
SOURCE: blackberry bold 9700 showing app error 523
With regards to your issue, error 523 reset means a "System process died" You'll neeD to reload the entire handheld OS again.
Here is how you go about it;
1. Install the software from the CD (that you received with the device), or download it from the service provider.
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes
Problem solved
Thanks and take care..
SOURCE: how do i solve the APP Error 523 on blackberry
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
SOURCE: blackberry bold 9700 showing app error 523, how do
cani stop a persistent reset on my att 9700 without desktop software or the apploader?
