Baumatic 23 in. BDW9 Built-in Dishwasher Logo
Posted on May 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, My dishwasher keeps stopping mid cycle and the door pops open. The soapy water is always gathered in the bottom and there's no way for me to get rid of the water, unless i restart the full cycle. The dishes are all getting stained with white marks, even though the salt and rinse aid is filled. Please help!
Anonymous
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on May 20, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
63
Questions
0
Helped
10908
Points
164
Sounds like the latch is worn out you mabe able to get a new one at appliancezone.com.... also check the drain for debris
Indesit D63 stops mid cycle
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
1helpful
Dishwasher stopping mid-cycle, water left in bottom, sometimes detergent dispenser does not open.
Man I love posts like yours. Makes answering easier.
In short, yes. You probably are right that the dishwasher is aborting mid-cycle, but the why is a tricky question. There are wet parts inside as well as moving parts and high temperature. It is possible your control electronics are being exposed to moisture mid-cycle, causing the dishwasher to cut out. This would have been easy to spot by the technician though. An alternate theory could be that the dishwasher's door sensor is stating that the dishwasher gets opened mid cycle due to all the shaking around. This wouldn't have been picked up by your technician and would cause the dishwasher to effectively "pause" itself without draining or using soap. Check and make sure the door is latched securely and see if it's easy to trigger the door sensor (pull gently on the door while the dishwasher is running).
Unfortunately, the best answer I have for investigation is to "babysit." Grab your laptop, pop in a movie, get a nice drink, and plop yourself down next to the dishwasher once you set it to run. The moment it stops working properly, take a look at everything you can.
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 • Dishwashers
Hi. I have a Brandt/Kleenmaid dishwasher. The bottom spray arm seems to be partially blocked since items like pots that rely on the spray from that arm to wash the inside are coming out partially dirty. I...
Your spray arm jets are probably clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
One more thing: the bottom of the door..on the INSIDE of the machine.It's amazing how much "gunk" settles and accumulates under there. I use an old toothbrush, moistened in soapy water to scrub the underside of the door. Then pour hot water on the area. Next run a regular cycle with NO items in washer and use 1/2 cup white vinegar...no detergent.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 21, 2011 • Dishwashers
3helpful
Water in bottom of dishwasher, how do i drain & reset?
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Apr 04, 2010 • Dishwashers
Water dripping from bottom off door during cycle where can I get a door seal
your overflow is most probably full, from turning off mid cycle and opening door and turning on again. take out of where it is tip up to a 45"angle water will come out, now don't turn off just open door.
MY GE Triton GSD5200 just stopped mid cycle...it is beeping and the normal cycle light is blinking. What is wrong?
I had the exact same problem. It was near the end of the cycle and it just stopped and then started beeping. I opened the door, and something seemed to pop. Looking at the mechanism, I'm thinking that the Jet Dry dispenser had gotten stuck somehow, and fiddling with the door loosened it. If it gets stuck again, I'll probably just remove it since I never use Jet Dry.
1helpful
STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
Nov 30, 2007 • Dishwashers
Top Baumatic Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
