SOURCE: sony trinitron not working
The power supply has failed which are very expense and your better off Getting a new T.V.
SOURCE: the standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage
has exceeded 33k and the unit goes immediately into safety shutdown.
Check power supply regulation and horizontal circuits.
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: My Sony Trinitron shut down last night. I
What is the likely problem if the Standby lights blink twice.
Thanks
