SOURCE: How do I turn off the write protect on the verbatim 4gb flash drive?
I solved write protection on my Verbatim store 'n' go 1 GB by this program "HT203 Handy Steno 2.0 Repair Tool" which format FLASH DISK from http://emea.apacer.com/en/support/downloads.asp . I know its different manufacturer but its working.
SOURCE: i cant format or put
Some Verbatims have a write protection switch on its side - make sure it's not activated. Then open the properties of the stick in My Computer. If in there the stick isn't set as read only then it has died - there's nothing more you can do to save it. Junk it and get a new one.
SOURCE: Verbatim Model #USBPRO500 Shows up on list of
use the source (pc/Mac) that created the data to remove it.
you will need to re-format to get it to work on the machine you are currently trying to use.
(personally I always remove all partitions and format to "fat" (remove factory) this will make the drive work on Mac as well as pc)
hope this helps
