In some cases installed drivers become defective for one reason or the other. You may try a free program from Glaysoft called GlayUtilities. Run the program and let it find faults. Clean the system when it finds errors. After the system is clean; reinstall the USB headset drivers and see if that works. That's a Start
SOURCE: i have windows xp pro
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=Headsets&name=LX3000&os=WVista_32&lang=en
SOURCE: Headset isn't recognized by computer and audio doesn't go through headset
With the infamous Vista, try:
Start --> Control panel --> Hardware and sound --> Sound --> Audio devices admin [I have a Spanish OS, I hope it is the same in the English version], then assign as default device the headset.
With Skype and other sw, you have to specifically pick the lx-3000 as the device that will be used as audio device (and the same has to be done to use the mic).
Pretty cumbersome....
SOURCE: Microsoft LifeChat LX 3000 volume buttons on remote does not work
I tried following eligiomanuel's instructions. I have exactly the same problem and it didn't help. I've tried everything I can think of. Does anyone have any suggestions?
SOURCE: how do i connect the Microsoft LX-3000 Lifechat headphon to x box
hi
how do i connect the Microsoft LX-3000 Lifechat headphone to x box 360, i
plugged the usb into the front of the x-box and its not working , i,ve
got no drivers, but i can down load them , but what do i do with the
drivers then?
SOURCE: just bought microsoft lifechat LX-3000 ,,,wnt work
You can download the drivers to make your headset work from:
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=LifeChat&name=JUG-00001&os=Win7_3264&lang=en
