Canon PowerShot S51S Digital Camera Logo
Posted on May 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The message 'Naming error' has appeared on the screen and is preventing me taking any photos. Canon S51S
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on May 19, 2011
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440585
Points
622693
From page 156 of the "Advanced Camera User Guide":
The file name could not be created because there is an image with the same name as the folder that the camera is attempting to create, or the highest possible file number has already been reached. In the Set up menu, set [File Numbering] to [Auto Reset]; alternatively, save all the images you with to retain onto a computer, then reformat the memory card. Please note that formatting will erase all the existing images and other data.
What's your problem?canon i9100 error 306
When you attempt to print from your Canon Printer using a Mac, a message appears stating Error 306. Solution
  1. Click the Apple icon in the top left of the screen.
  2. Click System Preferences.
  3. Click Print & Fax.
  4. If the padlock in the bottom left is locked:
    Click it, enter your password and click OK.
  5. Click the - button. to remove the printer and the + to add it again leaving the options on default..
4helpful
4answers
I have Canon G7 camera. It takes pictures and no ryme and reosan it erase it from card.It start giving you message of Memory card error fisrt I tought it vas the card. I have 4 different card with same...
That often happens as a result of a short on this model. Try emailing them at this site: www.camerasandparts.com They service the Canon Powershot cameras exclusively and they do excellent work, all for about half of what Canon wants. If you need help with it, that site is the place for a Powershot. They are excellent, send them an email and I'm sure they can help you with this problem. Good luck.
1helpful
2answers
Hello, i am having a problem with my Canon SD1200 IS camera, it was taking pictures fine, i accidentally left my memory card out in my computer and tried to take a photo with it out, but when i put the...
Hi Lara
I would take the battery out to reset it and put the chip in and then the battery and fire it up.
You can also clear the sd card in windows to avoid naming issues
After the card is accepted format it with the camera so the directory structure on the sd is restored
pls add thumbs if happy or leave me a comment if still in sorrow
cheers
rene
Jun 08, 2011 • Cameras
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
"naming error" message in the screen
Locate the removable drive On My Computer. Go to properties > tools >error checking
that should fix it.
Naming error
I replaced the memory card and this seemed to work OK.
1helpful
Unidentified Image
Usually the only time this message will appear is when you have taken the picture with another camera and try to review it on another. If this is not the issue, try formatting your card. Try another card. It may be a faulty memory card. If none of this works, call Canon tech support for free support.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
