There are a couple of reasons you could be having this issue. First, I would first suggest checking your brushroll and removing any hair or fibers wrapped around it. Second, check airflow and filters. remove hoses and rid them of any debris that may be trapped inside. Also, vacuum bags that are more than half way full will cause your machines suction to dramatically reduce. Thirdly, check to see if your machine is on the right setting. Some machines have a bare floor and carpet setting. Using the wrong setting will keep your vacuum from properly doing its job. Lastly, it may be a motor issue. If this is the case, I would suggest consulting with your local technician.
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
SOURCE: Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
SOURCE: The Dirt Devil Featherlite vacuum cleaner throws
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
SOURCE: Popped the lid open to
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
