You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
